hello again - still having problems with top cylinder in 92 evinrude 50hp. brief history ...
- engine started running on one cylinder
- swapped plugs when flushing and it ran on two
- no water evident in gear lube or piston
- took it for a test run this morning and will only run on top cylinder again
- changed plugs but only bottom cylinder fired
- swapped plug leads with no success
- compression seems ok, havnt tested but is blowing hard and clean (no water)
any ideas on next step ? could it be a faulty connection somewhere ? - it seemed for a split second it fired on two this morning.
any help muchly appreciated
