where do I find the engine ID for my Johnson outboard 2 stroke? the cover says 115 but I was told that it was not the original cover and that it is a 130HP not 115. Also need to identify the year. brian_harrod@hotmail.com
Found it, thanks, the ID is 135683G<br />I am expiereincing two problems with it right now.<br />1. It is hard to start when cold. a shot of starting fliud will get it going. sometimes you have to move the lever to hold the choke down and it will start. After you get it started, you can shut it off and it will start ok until the engine gets cold. <br />2. After it warms up 15-20min it won't stay idling. It will idle ok when cold (not sure of the RPM). After it warms up it will idle around 600rpm and try to keep idleing but dies. It will start right back up no problem but when you move the throttle down so you can put it into gear it dies. Also smells like it is running rich. The previous owner said that bigger jets were put in the carbs and the engine was also bored over. Can the idle air mixture be adjusted?<br />Someone had mentioned it might be an electrical problem like a coil pack. I have taken it in to have the idle adjusted twice and still have the same problem.Originally posted by bdh:<br /> where do I find the engine ID for my Johnson outboard 2 stroke? the cover says 115 but I was told that it was not the original cover and that it is a 130HP not 115. Also need to identify the year. brian_harrod@hotmail.com
