Hi All, quick couple of questions. <br />I have just bought a Quest 207 with an Evinrude 150 Oceanrunner, both 1993. Took it out about a wk ago for a quick test to see that engine/everything was working ok, engine sputtered at top end revs on a couple of trips down river but was also ok on others? The fuel in the boat was 1 yr old and I have now replaced the old fuel and filter as well so hopefully that should be fixed, any other possible causes? Also, the day after taking it out I had a good look through boat and engine and found the two wires from the remote oil tank corroded and severed, ive reconnected them and topped up the oil tank but a solid alarm now sounds from console? When wires are disconnected no alarm. I take it that the unit on top of the oil tank is an oil level sensor and not a pump to the engine? Other posts on similar suggest cleaning (as it may be gunged up) it and reinstalling, any other ideas on the alarm?<br /><br />Many thanks in advance<br /><br />Hamish
