Hello, I have a 1958 35 HP Johnson super seahorse with cooling problems. The motor sprays water out of the hole on the back at idle speed and it sprays water out of the hole at low speed, but it stops spraying water at high speed. Not even steam. I was told to remove the thermostat but it had already been removed when I checked for it. I started the motor with the the cover off where the thermostat would go and it sprayed out alot of water, telling me the pump is working. I was told perhaps the motor shaft was too short for the boat but it's a long shaft motor and the plate above the prop is 4 inches below the bottom of the boat and several inches if not a foot below the waterline. I ran the motor at high speed for a few minutes and when I cut it down I could touch the cylinders without getting burnt. They were hot but not "smoking hot". Does this sound like a partial block in the water jacket or something else?
