I just got a 92 Johnson 60hp. I no nothing about it mechanically, so I'm starting to check it out. How can I tell if the water pump is working besides waiting to see if it overheats?<br /><br />Other motors I see them spiting out quite a bit of water right above the water line. This motor has a rubber hose that comes out of the top of the motor and it runs down and comes out at the rear part of the engine compartment. It has a stream of water coming out of it that is probably a little smaller than a pencil, so I know something is moving some water. Is this good enough our should water be coming out somewhere else?<br /><br />Does anybody know how many tubes of lower unit oil this motor will take? 1 or 2?
