  #1
Old December 20th, 2003, 03:32 AM
dhazlett dhazlett is offline
Default Side-by-Side motor mount for older Pontoon Boat
Does anybody mfr. an option for a pontoon boat transom so I can mount the 70 as primary and 9.9 along side?I have a Smokercraft ESX or FSX (24')boat with two motors (70HP Merc Thunderbolt and 9.9 Merc). PA has several lakes with HP limit, while others are unlimited. It's a real chore switching motors for a day of boating or fishing, if we want to switch lakes. I know I share steerage, as there are products available. This boat already has both control boxes and I have another set of control lines.
  #2
Old December 22nd, 2003, 06:44 AM
jollymon jollymon is offline
Default Re: Side-by-Side motor mount for older Pontoon Boat
Dave,I do not know who manufactures, them but a friend has a 20ft Tracker, and the 9.9kicker is mounted on the end of the port side pontoon. He made his bracket after looking at some of the ones he saw in magazines. It slides into the brackets that the deck mounts to. He has a connection rod that he attaches to the kicker from the primary for steering and he has to throttle controls. He did his for the same reason HO limits on a local lake.
  #3
Old December 22nd, 2003, 12:54 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
jollymon has the right idea. I have had brackets welded onto the back of my toon and I can stand on them with no problem. Plenty strong! A good Aluminum welder should be able to set you right up. Weld a 1/4" bracket wide enough for the motor bracket to sit into and then bolt a piece of treated 2"by wood to it and hook her up. Check with the local Marinas as to who does good Aluminum welding.
__________________
Rick
"Boating is Life...All the rest is just Details"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
what makes boat rock from side to side? .) plus+ Boat Topics and Questions (not engine topics) 25 October 21st, 2006 04:44 PM
Boat walks side to side at idle jlash Boat Topics and Questions (not engine topics) 7 June 14th, 2006 06:52 AM
constant boat drift from side to side pocoloco Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 54 January 24th, 2006 04:44 AM
side mount control jjoediv Mercury & Mariner Outboards 2 July 24th, 2005 08:35 PM
Side Mount control for 25 HP hafnerj Non-Repair Outboard Discussions 0 July 21st, 2005 05:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
