Thinking about having my carbs rebuilt, but don't feel like hauling the whole boat down to the yard. If I remove the carb myself, will I have to fiddle with the idle and timing? <br /><br />Thanks in advance,
Re: can i remove carb without touching link/synch?
red - You should be able to I think. I did my 1987 V4 carbs last year and pulled both carbs off without disconnecting them. By the way this is a easy do-it-yourself job.
