chatt14784
- Jun 30, 2004
- 4
I took the hoses off the t-stat housing and the inside ( what I could see had a a lot of build up.<br />this is a 1989 /88hp what is the best way to clean/flush the entire water/cooling system?<br />SHould I put in new t-stats?, can you run with out them? the water I run is is 88+degrees
