sparkplugs on a merc 500.
rolmops
Hello Guys.<br />The merc I was given is #2160244 which makes it a 1967.The plugs I found in there were champion L78V and my manual says it should be L4J.Is L78V a factory adviced replacement or is it a mistake by the previous owner?<br />Thanks in advance,Rolmops
emckelvy
Re: sparkplugs on a merc 500.
Depends on whether you have the standard ign model or the "SS" model. The magneto-ignition model would take conventional plugs, while the electronic-ignition "SS" model takes surface gaps. However, L78V is too hot of a heat range for a 50HP and instead you should be using L76V's or equivalent.<br /><br />BTW you can use conventional plugs in a CDI model, but don't use surface-gap plugs with magneto ign as the mag doesn't develop enough voltage to fire them properly.<br /><br />You can tell if yours is a magneto if it's stand-alone with no other coil or electronic components connected. The electronic ign model will have a separately-mounted ign coil, and a switchbox (power pack or CDI unit) mounted on the front cowling support.<br /><br />BTW you'll probably get more response posting your Q's over in the Mercury forum!<br /><br />HTH...........ed
rolmops
Thanks for your reply.<br />I just saw ,that I posted in the wrong forum.My apologies for that JB.
JB
To Merc Troubles
