  #1
Old September 6th, 2004, 06:31 PM
cowboyup cowboyup is offline
Default 1991 Evinrude 150 powerhead check valves
Upon inspecting my repaired powerhead, i noticed three small, oil passage holes for the crank and three small holes on both faces where the intake manifolds mount. I've cleaned all the oil and drain passages with compressed air. Which ones are supposed to be check valves? And wich way are they supposed to direct flow? Thanks ahead of time.
  #2
Old September 7th, 2004, 09:18 AM
angus63's Avatar
angus63 angus63 is offline
Default Re: 1991 Evinrude 150 powerhead check valves
I believe you are talking about the recirculation valves. Routing is in manual (DO NOT GUESS). Easy way is check any early 90's 150/175hp motor for recirc valve locations and hose layout.Good Luck
__________________
USMMA Kings Point
  #3
Old September 7th, 2004, 11:33 AM
I've been looking through my OMC service manual to find out if those brass colored inserts (in the powerhead itself...three on each side where the intake manifolds mount) are check valves or just straight bore oil passages. It does very clearly illustrate the routing of the hoses but does not show the location of the in-line check valves. My parts catalog only shows 3 in-line check valves but again, no location.
  #4
Old September 7th, 2004, 09:08 PM
angus63's Avatar
The brass fittings are the valves (one per cyl). Soak em in alcohol and blow them out before reusing.
__________________
USMMA Kings Point
  #5
Old September 7th, 2004, 09:25 PM
Walker Walker is offline
The check valves are on the intake manifold and have a 5/15" or 3/8" head on them and can be unscrewed. The other ends of the hoses go to nipples that are just pressed in. The check valves are one way flow outward to the hose.
  #6
Old September 8th, 2004, 05:35 AM
I hooked up my compressor air hose to the 90 degree nipple (on the powerhead) on the back side of where the intake manifold mounts. I heard air coming from the brass pressed in fitting on the same side (opposite from nipple) as the intake manifold mounts. I heard a little air, but when i pressed a paperclip end slightly inward (inside the brass fitting), the air rushed out. They must be a combination 90 degree nipple and check valve pressed in. Question is, how can i replace (press out) these. Do i heat it up with a heat gun, butane torch or other. Are they sealed in with gasket maker or some other goo? I've got three that the check valve is missing (#1,#4,#6). Question #2 is, what harm will it do if i don't replace them? thanks again.
  #7
Old September 8th, 2004, 09:50 AM
I don't believe that's a check valve. And the ones that are missing do need to be there. You will have running problems without them and also will have raw fuel spitting out the holes into you powerhead compartment. Good way to set your motor on fire.
  #8
Old September 8th, 2004, 02:35 PM
seahorse5 seahorse5 is offline
Give us your model number as there were 90 degree 150's and 60 degree 150's that year, and each had different designs and recirculation systems.If you don't have a model number, is your trim switch on the port or starboard side of the motor pan?
  #9
Old September 8th, 2004, 02:49 PM
thanks Walker, but I've donned the jewelers glasses and can see what appears to be a metal flap (spring loaded?) inside that flush mounted brass fitting. I'll take pics to clarify this one. Thanks for the fire tip...however, i might just set this one on fire myself before i finish.
  #10
Old September 8th, 2004, 02:53 PM
My model numbers are E150EXEIS and E150NXEIS. Like i said, I can't seem to find them mentioned in my service manual. It does point out the ones with a 5/16 or 3/8 head alluded to earlier on the manifold itself, but nothing about the ones on the powerhead.
  #11
Old September 9th, 2004, 01:05 PM
I've taken pix of the inserts/check valves in question. Ok, i had one of our I.T. guys set me up with this address. Let me know if it works. http://152.20.76.250/iboats/motor/blockinserts.jpg
  #12
Old September 9th, 2004, 01:39 PM
You have a 60 degree motor according to the image you posted. Your recirculation check valves are on the "plastic" intake manifold, each cylinder has 2 round "discs" at the bottom of each intake bore. The "o-ring" formed seal loops around each one. Don't use compressed air to check them. Use a plastic srynge with a piece of tubing on the tip. You can use Bombardier ( OMC ) Engine Tuner to clean the valves, fittings, and lines.Be sure you use the new tan colored intake gaskets, as the original black ones would swell and cause air leaks, due to chemicals in reformulated fuels.
  #13
Old September 9th, 2004, 02:14 PM
Thanks for replying so fast. I've carefully looked at the intake manifolds and seen the check valves "discs" you described. About the "clogged" brass inserts...how can i clean them out? It feels like a solid metal piece in there. Drill bit perhaps?
  #14
Old September 9th, 2004, 02:31 PM
Use a plastic syringe with a piece of tubing on the tip. You can use Bombardier ( OMC ) Engine Tuner to clean the valves, fittings, and lines.
  #15
Old September 9th, 2004, 02:43 PM
I'm speaking of the ones on the powerhead, as shown in the picture.
  #16
Old September 9th, 2004, 03:27 PM
kgw kgw is offline
okstatefan,the brass fittings on the power head side have very small holes in them a paper clip will not fit. these are press fit in block and can be twisted out whith vise grips,but then you have to buy new ones . do as suggested and see if alcohol will flow through with a syringe.
  #17
Old September 10th, 2004, 05:21 AM
Alcohol works fine on three of them.The other three are missing. I can't find the part number in my parts catalog, or any mention of them in my service manual. Could i put in-line check valves on the recirc lines instead?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
do the 150 1981 evinrude v 6 have recurculation check valves Benny1963 Johnson & Evinrude Outboards 1 February 28th, 2007 09:08 PM
do the 150 1981 evinrude v 6 have recurculation check valves Benny1963 Johnson & Evinrude Outboards 0 February 28th, 2007 08:20 PM
does anyone use check valves on bilge pumps minocqa Boat Topics and Questions (not engine topics) 3 October 18th, 2005 06:42 AM
Fuel pump check valves. shelbert Mercury & Mariner Outboards 3 May 28th, 2004 03:53 PM
Recirc check valves bonitoman Yamaha & Suzuki Outboards 8 February 12th, 2004 08:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
