9.9 Evinrude Motor Runs Briefly then dies
nbarnard
This is a 1995 9.9 Evinrude. We replaced the Tank, fuel line, and the pump that pumps the gas from the tank to the motor. When I start it and start going, the fuel pressure is lost and the motor wants to die. If I don't pump up that pump going to the motor it dies. It got the point the other day when that method didn't help. It would idle for a little bit but then die when I tried to put it in forward.<br /><br />Any Ideas?<br /><br />Thanks,<br />Nathan
wayne h
Master Chief Petty Officer
Re: 9.9 Evinrude Motor Runs Briefly then dies
sounds like a fuel pump
alumistar
definitely fuel pump, but, the one that feeds the carb. not the one between tank and motor
nbarnard
Any idea how much a fuel pump will cost for that?
wayne h
they should be rebuildable check your local dealer for a rebuld kit
