Re: Sputters and Coughs a bit
For what it's worth, just one comparison: My 175 of the same era had a horrible sneezing problem at idle, often almost quitting, occasionally actually quitting. But really started and ran pretty good other than that. All the advice I got was that it was caused by a lean condition for whatever reason - often dirty carb jets, but could be anything. I was also advised that "perfect" idling is often not possible with large carbeurated 2 strokes, it's just the nature of the beast.<br /><br />Given that, I convinced my (good) mechanic that the sneezing I had was not within the realm of imperfect two stroke idling, so he agreed to spend some time (he doesn't like to waste his time and my money - I like that) troubleshooting it and would clean the carbs if need be. He found some sort of missing or damaged plug thing in the VRO/fuel pump. My VRO is disconnected and I premix. Evidently this is one of the parts that is plugged off when it's disconnected. So it was evidently causing a significant air leak, lean mixture at idle, and therefore the bad sneezing condition.<br /><br />That definitely solved the sneezing problem. It really idles very, very nicely now. I'm very happy with the result. I also noticed there's significantly less black oily exhaust residue messing up the leg.<br /><br />For what it's worth, of course. Good luck.
