Re: How to empty my gas tanks?
A friend of mine has a 24 footer with 2 fixed tanks, and this is how he fills his: we stop at gas station after fishing and one guy gets in the boat and turns power on so electric gas gauges work. The person pumping gas does so till guy in boat sees gauge hit full, and tells pumper to stop. My friend knows that the tanks will have enough room for one more gallon of gas plus whatever oil it need. He than writes down which tank and how much fuel it took plus one gallon(the one that he will add later with the oil mixed into it). At 2.56 oz per gal.,aprox, he puts oil in a small gas can, adds 1 gal of gas, mixes it up a bit, and adds to whichever tank it's for. It'll all mix togeather on the trip home and the next trip to the lake. The last fillup of the season he adds stable. As for draining a portable tank, on my 17' runabout, I unhooked the fuel line off of motor, stuck a small screwdriver in the end to hold checkvalve open, put end in container I wanted to transfer fuel into and sqeezed the bulb till fuel started flowing. It was slow, but cheap(nothing). If I ever do it again, I would unscrew the clamp and remove the connector. Mark your gauges with whiteout at gallon increments if it's the corkscrew type gauge. There is always some way to solve a delema. PDS
