Hi all,<br /><br />1976 20' proline, 1983 200hp johnson. MY steering is very rough. I have two grease fittings on my tilt tube as I think it is called. Are those for steering or for the tilt/trim? If the are, do you know where the correct fitting MIGHT be, and what lubricant is best to use. I may juts pull the whole steering line off anyways, but looking for a short term fix.<br /><br />Thanks, Scott
