Re: Year and Equivalent?
Hi Elto25,<br /> As a state-side Hip Fan, I see them whenever I can - which has been three times so far... I'm not too far from their hometown, Kingston, ONT....<br /> As for the revs - if you're using a stock aluminum 3-blade, keep the revs under 5500. Find the tallest (highest pitch) prop you can find for now. Those big bore, long stroke motors can toss a rod through the block if they're over-revved. They are rated at 4500 RPM, but I've found that they can handle about 1000 over that without too much trouble.<br />- Scott
