Re: 1990 90 hp johnson, losing power
Revving in excess of 2500 in neutral(no load) does not pose the same fuel volume requirements as revving to 2500 in gear under load.Just like traveing down a level road at 25 mph does not pose the same fuel requirement in your car as traveling at 25mph up a steep grade.Enough of that.Actually ,you should never rev an outboard over 2500 rpms out of gear ,out of water.<br /><br />To eliminate the possibilities of why the primer bulb will not pump up to firm and hold,you'll simply have to use the old fashioned process of elimination.One component at a time.Check the pickup tube for splits or leaks.If that's good, go on to the next possibilities mentioned.<br /><br />You never answered whether you are getting the initial alarm tone when key is turned on ,so we can't rule out an overheat and whether the engine is going into s.l.o.w.<br /><br />Yes a defective bulb can cause fuel flow problems.Is that what's doing it??Heck I don't know ,I can't touch it from where I sit.Does it go flat when the engine falls off?Can you pump on it and get the engine to pick up?If so your fuel pump may be defective and won't keep up at higher rpms.Check for a leaky pulse hose to fuel pump diaphragm.Crankcase vacuum and pressure pulses is what drives the fuel pump via a rubber hose.<br /><br />Can you bump the key primer repeatedly and get the engine to pick up? If so ,it is indicative of a fuel restricted carburetor ,since it allows fuel to bypass the carburetors and flow straight into the intake chamber.<br /><br />All of these questions are relevant.Troubleshooting is simply a process of elimination,but if you don't eliminate some things ,then the rest is just a shot from the hip.<br /><br />In summary,many different things could cause the very symptom that you are experiencing.Start with the easiest and work your way to the more difficult items.Good luck and tell us what you find.
