kidwalleye
- Jun 24, 2004
- 2
i have a johnson 20 hp ,model # 20cr79r, i have just bought a starter and a selonoid for it,{did not have one before}. i need a wire diagram or some help if someone could, i have a positive wire running from starter to one side of selonoid, i assume i run the positive off the battery to the other side of selonoid.then i would guess the negetive from battery runs to the block of engine? there are two posts/bolts{smaller}on top of selonoid. Are these for starter switch? how do i wire that switch? and does the motor have a wire for recharging battery
