Re: 70 HP 1987 Johonson won't idle unless......?
I'm with Rick on his earlier post. Run the 13 1/4 X 17 prop you have on that engine.5300 at wot is too low for the 3 cylinder loopers.And with a low compression cylinder on the bottom end the engine can use all of the breathing room you can give it.At 5300 wot rpm capability,that engine is being lugged at all throttle settings.<br /><br />I'd still give those carbs a once over cleaning as well.Could be that the bottom hole compression is a result of either a present or past lean condition.<br /><br />Also ,I don't know what product or procedure you used for the decarb,but you could try removing the bottom sparkplug after and engine warmup,rotate the flywheel until the piston is near top dead center and target spray some decarb(omc engine tuner) diectly around the cylinder wall. Let it sit for several hours.Then follow that with stroking the piston by hand ,using the flywheel,several rounds,and then a hose run for several minutes and recheck compression.This is under the assumption that there is possible heavy coking of the ring grooves from lugging the engine over time and could maybe improve the compression condition a bit.May or may not help ,but sure won't hurt.Good luck in any case.
