Re: How to check if stator is faulty
First you need to check the resistance of each coil and you need to know what value is normal for your stator<br />Second check to see if the two coils are grounded . They should have infinate resistance to ground<br />third check to see if a voltage is being produced across each coil when you turn the motor over.<br />If a voltage is being produced then place one lead of the voltmeter on the coil and the other to a good ground. There should be NO voltage to ground.<br />You probably should invest about $35 and get a manual so you know what resistance and voltages are proper,
