  #1
Old August 16th, 2004, 10:42 PM
sonnyjanet sonnyjanet is offline
Default throttle cable 90 evinrude
I had to take off my air silencer and silencer back plate which holds the throttle cable and the thumbwheel on the throttle cable moved. My clymer manual gives no instruction whatsoever on this 1986 90hp V4 on how many threads should be showing or what length of threads you should see.My engine is hard to start now and I would like the correct way on how to adjust my throttle cable. Thanks.
  #2
Old August 17th, 2004, 04:49 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: throttle cable 90 evinrude
It's a matter of trial and error to get it adjusted right... Threads showing have nothing to do with it..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old August 17th, 2004, 04:07 PM
DJ DJ is offline
Just make sure the throttle opens up all the way and comes back to rest on the idle adjustment screw.
  #4
Old August 17th, 2004, 04:37 PM
DHPMARINE DHPMARINE is offline
sonnyd, correct adjustment is so that the linkage returns HARD against the idle srew after being BOTH in forward full speed and reverse full speed.I use a piece of paper,usually a dollar bill,(handy) between the screw and the block to make sure there is no space.Adjust the trunion (thumb wheel) until this happens.You don't have to run the engine to do this,just hand spin the prop if things are binding (or stiff). What concerns me is when you pulled off the silencer back plate.Some years have a fuel enrichment valve bolted there.If yours does,you may have disturbed the lines to it,or pinched them during reassembly. This valve 'squirts' fuel into the intake when cranking and pushing in the key to start.It is your choke. No choke.... hard start.DHP
  #5
Old August 17th, 2004, 05:27 PM
marinemech marinemech is offline
throttle cable installation:shift control to forward gear then move handle 1/2 way back to neutral pull cable to remove backlash pull throttle arm against idle stopadjust trunion to fit in pocket do not preload the throttle cable
  #6
Old August 23rd, 2004, 09:22 AM
Thanks for the info on throttle adjustment. I found my main starting and idling problem. My bypass covers are leaking. See new topic bypass covers leaking. This started as a slow leak and I could not find it. FYI, If you really want to find a leak,1. degrease and dry the engine really well 2. wait until dark and hook up the ears and start the engine and let idle. 3. Use a super strong hand light, like a battery pak powered ryobi. 4. The reflection off of the oil and gas is incredible, it can't hide. What was happening it was leaking in the back of the engine. When I would trim up the engine for transporting on trailer, the fuel would run down underneath the carb and fuel areas making me think the leak was up front.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15 hp evinrude needing throttle cable feldpaum1975 Johnson & Evinrude Outboards 2 February 11th, 2007 04:08 PM
Evinrude 90 HP Throttle Cable Stretched? wammer Johnson & Evinrude Outboards 2 July 31st, 2006 03:56 PM
Evinrude throttle cable wishniwasfishn Johnson & Evinrude Outboards 3 July 18th, 2006 10:28 PM
Throttle cable 1980 4.5 evinrude voodoo Johnson & Evinrude Outboards 2 March 12th, 2006 03:01 AM
Evinrude throttle cable setup longitude Johnson & Evinrude Outboards 0 May 7th, 2003 05:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
