johnson 70´-60hp - 90´-60hp.
ivannielsen
Hello.<br />Does anyone know if a 60hp johnson engine from 71´will fit a johnson 60 hp from 90´with trim&tilt.<br />Best ragards Ivan Nielsen
ivannielsen
Re: johnson 70´-60hp - 90´-60hp.
Hi again.<br />I see now that i was´nt specific enough before..<br />I have a good powerhead from 1971, and want to mount it on a "leg" with trim and tilt from 1990.<br />Does the axel fit each other, or is this i'a bad idea.?<br />Kind regards Ivan Nielsen
Chinewalker
Hi Ivan,<br /> It won't work. The driveshaft splines are different for one, and two, the '1970 model was electric shift and the 1990 model is mechanical shift, meaning the 1970 model doesn't have the various linkages, etc. required to operate the 1990 model... Many other reasons, too, but those are the biggest ones..<br />- Scott
