  #1
Old August 10th, 2004, 03:36 AM
Simon Jordan Simon Jordan is offline
Default 1988 Evinrude 120 V4 stalling at low revs
I have owned the engine since new and know it does not like to idle for too long. However the problem is now terrible, the engine will cut out as soon as the revs come down. It will more often than not cut out as soon as you engage gear. It will not start easily. Then is slow to pick up using the manual throttle. It only runs well on half to full throttle. It sounds like it is fuel starved at low revs, but I have replaced the fuel line, plugs. One thermostat is on order as it is stuck open.
  #2
Old August 10th, 2004, 05:18 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 1988 Evinrude 120 V4 stalling at low revs
Welcome!Go ahead and change both t-stats. It sounds like the carbs may need a good bath. Those motors should idle great no matter how long.Make sure youre using fresh 87 octane and Champion plugs.That motor has the Quick Start feature. If one t-stat is stuck open and it happens to be on the bank that has the sender for Quick Start, then the motor could be stick in Quick Start. If so, and youre trying to get the motor to idle down manually it could act as you describe. If it ever does come out of Quick Start it will be set so low it will stall. The idle has to be set with the boat in the water (for backpressure) and the motor out of Quick Start.Make sure the water control valve (controlled by the throttle arm) is working properly. In fact if youre going to change the t-stat, I would go to the 1993 style t-stat. Youll need the cap and spring for each head but you can eliminate that control valve and those hoses.Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 25hp missing , stalling ? 63split63 Mercury & Mariner Outboards 2 August 28th, 2006 04:20 PM
DT25 occasionally stalling and rough at low revs quietstorm Yamaha & Suzuki Outboards 2 January 25th, 2006 02:38 PM
omc 3.0 1988/ max revs and torque TUGSGF Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 May 7th, 2005 07:55 AM
1988 85hp force stalling jmrrich Force & Chrysler Outboards 1 July 30th, 2002 03:34 PM
1988 110 hp evinrude stalling stedfast Johnson & Evinrude Outboards 3 April 1st, 2002 04:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
