meno mosso
- Jun 12, 2004
- 1
My 2000 90 hp Johnson overheated while running at around 4000 rpm for 30 minutes. I believe the overheating was caused by a large sheet of plastic that snagged on the fin at the bottom of the motor, restricting water to the impeller. After removing the plastic from the motor, the red warning light on the dash went off after about a minute. Now however, any time I run above about 2400 rpm, the engine runs very rough and provides no additional power. Below 2400 rpm, it seems fine. I limped back to the dock at 2300 rpm, running for about 20 minutes. Any ideas what causes this? Could I have done permanent damage by continuing to run the motor instead of waiting for a tow? I removed the prop, and there is nothing tangled around it. Beyond that, I have very little knowlege about what I should do next.<br /><br />Thanks in advance for your help and advice.
