cvader2000
- Jun 5, 2004
- 7
I took apart the starter and cleaned it up. Could still use a rebuild but it now works. The pistons are moving nicely now. The spark plugs are sparking (I tested them). Problem is, no fuel is getting to the cylinders.<br />I'm still waiting for the manual to arrive so I could use some help identifying some parts in the meantime.<br />Fuel pump: Is it the unit that's on the right side that the first fuel line goes to or is the small unit on the left side after the carb? If the one after the carb is not the fuel pump, what is it? It has a wire from it to what I think is the neutral safety switch. It also has 2 wires connected to the center of it but they are cut off.<br />Also the unit under the carb; Is that the choke? The rubber boot on it is dry-rot. Can I replace just the boot or should I replace the whole part?<br /><br />Thanks,<br />Charles
