striperbob
- Jun 10, 2004
- 3
I have a 1989 evinrude 48 hp spl which last year when i took out the overheat alarm activated. Since then, i have not been able to get it to full throddle except by directly injecting fuel via the cold start injector/ choke. i have tried idling for several minutes to reset, replaced fuel line/bulb, and thoroughly cleaned the carb & jets. Fuel filter seems fine.Seems like something is limiting the rpms to about 30%. Water pump semms to be working fine(Good water pressure).Motor idles and sounds solid.<br /> ANY IDEAS
