chuckybaby
- Aug 25, 2002
- 49
I have a '94 200 Venom. In 98, a ring locating pin came loose, got thru a transfer port into the crankcase and destroyed the block. OMC provided a replacement block at a very reasonable price. I have learned that several (many) of these engines have done exactly the same thing.<br /> <br />My new block is running fine but I really don't truct the thing as far as I can throw it and I expect it to blow up any time I start it.<br /> <br />Can anybody comment on how common a failure this was, whether OMC did anything to correct it and if so, how can I tell if the mod is done on my block. Also, is there a way to tell if the ring locating pin is starting to work loose...maybe pull the heads and look at the barrel ?...compression test?...<br /> <br />Any comments or insight would be appreciated.<br /><br />C
