Re: Converting 85hp to 125hp
Any of the 1969-72 V4 powerheads 85/100/115/125 will swap. There are only minor differences in displacment between them (range from 94 to 100 cubics inches). The 115s and 125s run bigger carbs (1 5/16 versus the 85hp 1 3/16), not sure what the other differences are, presumably mostly porting. Those differences move the power up the rpm band, which means the 85 will have a fatter midrange, and the 115/125s have more top end. You may not feel a huge difference on your boat, particularly if your aim is to pop up skiers or push a big boat, rather than just top end speed. I have run a few examples of both on the same test prop, and can tell you that on the top end there IS a substantial difference between the 85s and the 115s. <br /><br />You might try just a pair of 1 5/16 carbs (I have a pair off a 125 for $20 if you want to try them,
jslobvan@exit3.com). HOWEVER, first make sure your current rig is optimized. The motor wants to be as high on the transom as possible, without losing water pressure or cavitating the prop too bad on turns. Once there, prop is to turn at least mid5000s with you alone in the boat. <br /><br />If the powerheads are both freshwater & not too corroded, swapping them off isn't too big of a job.
