Re: Evinrude 150 trim/ tilt problem
According to my Evinrude manual check the following. Will not trim or tilt down.<br /><br />1. filter valve seat ( under the resevoir)<br />2. Manual release loose<br />3. Impact sensor valve (also under the resevoir)<br />4. Pump control not opening trim check valve.<br /> under the tilt motor, you can take out with <br /> drag link( best bet, you can get at NAPA <br /> for about $11. part # ns-91) or big screwdriver.<br />5. trim check valve plugged. <br />6. Expansion relief valve (locked in full tilt <br /> position.<br /><br />you have to take the motor off the boat to get to all except item 4 above.<br />I have the same problem right now. I cleaned the trim valve and it worked until I got it back to top tilt. Expansion valve is my next move.<br />I would get a maual before I attemped it though.
