Changed my water pumps and took my boat to the river to knock the cobwebs off before going offshore next weekend. After running wide open for about 45 minutes and then 1/2-3/4 throttle for about 45 minutes, decide to call it a day. Slowed back to idle to move some stuff around and the overheat warning goes off, felt pee stream, it was hot. Shut it down and let it cool off. After it cooled down, started it up and felt the water coming out of the pee stream and the exhaust holes. Exhaust water overflow was hotter than the other engine, pee stream was cold. After all of this, the motor does not seem to want to take off when I give it the gas. Any ideas on the overheat/stall off idle? Any help would be appreciated.
