Re: 2 stroke mix ?????
You are getting good advice, the only way you could mix 100:1 is with the Amsoil Saber that is blended to run at that ratio, Truth of the matter is that Amsoil is not TC-W3 certified, but is rated as a TC-W3 or better. (Not NMMA certified though) I myself, even though an Amsoil dealer tell people , (depending on there use) to run it at 80:1. If you are doing a lot of trolling, you can run it at 100:1, and you couldnt find a better oil in that application. Some, if they are running at WOT for extended periods to get to where they are going to troll, will have two tanks, one for the trip out, and one for trolling.
