badjohnson
- Apr 28, 2004
- 22
engine randomly sounding fuel restriction alarm and check engine light comes on. usually when cruising 4000 rpm's or so. i usually slow down a little and alarm stops after a few seconds.<br /><br />the hose clamp around primer bulb was broken, so i figured was getting air and i put a new clamp on. when priming before start and when alarm goes off, the ball is soft and full of air. shouldn't it hold gas.<br /><br />I see many post referring to sticking anti-siphon valves, but wouldn't that cause ball to collapse rather than get soft. <br /><br />any advice would be appreciated.
