Thanks for the info voodoo! Much appreciated.
So, perhaps that's what the beeping (Sounded like sonar) comming from the console may have been? Overheating? Very strange, twice while out on the boat the console started making the sound described above, although it does not match with anything I've read as far as warning alarms. It started very slow, as if like sonar there was an object far away, then sped up to become very rapid, then slow down again. Very odd... Any how...
If it was in fact overheating, would there not have been some sort of evidence of a problem? i.e. lack of good strong stream from p-hole? Evidence on the head gasket and around the head and cylinders of water leakage (deposits)?
Not sure which side is the exhaust side. If when standing at the back of the engine facing forward it's port side, then yes, that's where the "chunk" blew off.
However, like you say, only 1 cylinder is smoked... and thinking lean condition on that cylinder.
As far as the VRO... heard some people say they disconnected the oil line and just mixed gas. Suffice to say, at this point I'd rather not leave anything to chance...
Thanks in advance!
Ben
