fishingrey
- Jun 2, 2004
- 6
My counter motor is overheating. at idle water spit is normal ,when i hit the 2000 rpm mark the motor stops spitting water out of the tell whole . the motor heats up and the temp doesnt come down..even with the water coming back somewhat to the tell whole , when temp reaches 180 i shut the engine off to prevent damage to the head. i have replaced the whole water pump including bottom plate, key is in proper place.. I removed both thermostats, also idle some to see water gushing out of thermostat housings. compression 125 and above on all cylndrs. help!!
