  #1
Old November 8th, 2003, 03:14 PM
hollowoods hollowoods is offline
Default Adding third pontoon setup question.
Hi Guys,I've got a 24' toon w/ an '89 120 Evinrude. My plan is to add a third tube. The new 24' tube has some rub thru damage in the side of one section. My plan is to cut a 3-4'section out of the center of the damaged tube and re-weld. This will result in the center tube being a foot or two aft of the other noses once it is mounted, forward of the foot. All the tri toons I've seen have the center tube shifted forward.Does anyone think I'm headed for trouble?I look forward to having you guys share your thoughts on this topic, as I have learned a lot from reading many other threads.Thanks,Hollowoods
  #2
Old November 8th, 2003, 04:32 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: Adding third pontoon setup question.
I went through this same discussion with a welder friend of mine who works on toons and replaces logs all the time. He also adds 3rd logs. You are right on track the way you want to do it. The only thing I would say is that I don't know how being aft of the other logs will affect things. I would have him mount the log so that the nose is just ahead of the existing logs. Being a little short in the rear will not hurt a bit. You will still gain the lift you're after, even if the log is forward of the transom by a few feet. On my 20'er, he was going to mount a 15-16' log, or even a little shorter, one foot in front of the other logs and let the rear of the log sit about 3' from the beginning of the transom. He said that was the way to go. You do not want it to block water flow to the transom. If your toon is built like mine, the transom mounting protrudes forward of the rear of the boat by about 3'. This means in my case, if I put a 16' log in the middle and let the front extend 1 foot in front of the existing logs, the rear of the log will be 2-3 feet in front of the transom where it begins at the stern. This is good! Even extending it a bit further in the front would be better for water flow to the transom. Remember, the prop has to have unobstructed water flow to it or bad things will happen. Have him mount it 6"-1' in front of the others and it will work out fine.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
boatmanwayne boatmanwayne is offline
Hi Hollowoods, heres what I have found by trial and error on this setup. The addition of the third tube does need to be equal or forward of the two outside tubes. Reason is, the inner wake from the two outer tubes will come together in the path of the third tube thus creating as much or more water pressure for the tube to part, hence creating more drag, also the rear of the tube needs to be 3 to 4 feet in front of the leading edge of the lower unit, otherwise it will push the water down somewhat allowing the lower unit to cavitate. Or the tube can be placed directly in front of the lower unit, but the engine will have to be lowered some, thus creating a little more drag. Hope this is easy to understand, I had to move mine once to make it work correctly. Hope this helps.Wayne
  #4
Old November 8th, 2003, 05:33 PM
JB's Avatar
JB JB is offline
Moving to Boat Questions.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pontoon boat / motor setup marunr Non-Repair Outboard Discussions 13 June 6th, 2006 06:01 AM
Trolling Motor Setup Question hct4all Electrics, Electronics and Trolling Motors 1 May 10th, 2005 08:39 PM
adding a 3rd pontoon log to 2 log boat djwalters Boat Restoration and Building 12 November 20th, 2004 11:28 AM
Adding transom bracket to 24' pontoon boat dhazlett Non-Repair Outboard Discussions 3 May 9th, 2004 05:35 AM
Adding third pontoon setup question. hollowoods Boat Topics and Questions (not engine topics) 11 November 19th, 2003 07:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
