Just picked up a 68 Johnson that me and some friends fixed up. It starts ok now but the shifter is busted up. I can see it's broken inside the casing so the shifter handle moves forward and backwards without any tension. I belive the cable is still good. It's just a little mount on the cable inside that gear box that is cracked in 2 pieces. Any help on "epoxy'n" or glueing this back together...Or is this a cheap part I should just replace. Also, where would I look for a new part like this if it can't be fixed?<br /><br />Hope I described this well enough to understand but this is my first boat and I don't know too much.<br /><br />Jason
