Air vavle leading to carbs??
Hotrods
Hi all,, I just purchased a 1993 Evenrude 115hp,<br />Rebiult ..I noticed a air valve plug on the top that looks like I could push Compressed air into the CArbs, What Is this for..?<br /><br />Thanks
sgcheek
Re: Air vavle leading to carbs??
Sounds like what you are referring to is the cold start primer with the fitting that you can attach a long term storage fogger hose onto for preserving the engine for non usage sauch as winter. The fogger oil comes from your local dealer with the hose attached to it.
Hotrods
cool I'll have to look into that........<br /><br />Edit...........<br /><br />Yup thats what it is, to Add the fooger to the carbs for winterizing.. Thanks again.
