'66 Johnson 80hp ,no Spark
mandolinbob
I have a 1966 Johnson 80hp Electramatic.(V4AL-18C) There is no spark at the plugs. I have 12v at the coil when ignition is on.Safety Switch is OK.I DO NOT have the Remote Control hooked up and ,of coarse, the Shifter Toggle Swith is not hooked up.Does the ****er Switch have to be Connectd? If not,can you suggest other remedies?<br />Thanks much, Mandolinbob.
