wave wacker
- May 29, 2004
- 2
Does anyone know how to disconnect the shifting linkage on a 25 johnson? I need to replace the water pump. I checked the other posts, but couldn't find a solution. There is no two piece linkage in the lower unit, no cover near the top to get at the shifter or bolt under the carburetor. Do I need to remove the powerhead or do I need to pull the shifting rod and handle out from the side of the motor.
