I have a 1983 150 V6 Johnson Seahorse. Recently my father-in-law took my boat out and ran all of the gas out the boat and drain the battery while attempting to start the engine again using the reserved tank in the boat. After getting towed in and replacing the battery, the boat has not run the same since. At first it would just take a little longer to plane but now it will not plane at all. I took the boat to a local shop and they clean and soak the carbs and jets but I am still having the same probelm. The engine seems to max out only at about 3000 RPM. The compression readings for the engine are:<br /><br />2 = 80 1 = 80<br />4 = 85 3 = 90<br />6 = 75 5 = 85<br /><br />Does anyone have any suggestions on where to look next to help solve this issue?
