Re: 150 hp johnson power tilt .1986
Hi Steve. Welcome to the iboats forums.<br /><br />Have you checked the TNT fluid level in the reservoir? Don't forget to do this with the engine tilted all the way up.<br /><br />You may also raise it all the way up and use the manual release to drop it a couple times. You may just have a stuck valve in the the pump unit.<br /><br />When trying to run the engine down, have someone gently push down on the motor. This may also free a stuck valve.<br /><br />Keep us posted.....thanks.
