1963 75hp runs then dies
willikc
i have a 1963 75hp it will run for ten seconds or so then dies it will fire right back up. i just got the boat it hadn't been started for 4 years before i got it
alcan
Re: 1963 75hp runs then dies
Hi Will<br />Check out the FAQ section. Do the few simple tests, then post back with your findings, and more info. Your not giving us much to go on.
willikc
is the timming mark on the dist.pulley supposed to line up with kill switch or the line on top of the mounting bracket? i have a manual ordered should arrive next couple days.
jimmbo
It is used for setting the timing with regards to the flywheel. Marks on dist pulley line up with mark on bracket and dot on flywheel is aligned with mark on block or flywheel/ring gear cover.
cjones4@hvc.rr.com
I have the same motor. I've found it needs points, condensor, plugs, fuel filter at least anually. Also a good dose of carb / choke cleaner to free up the choke. If you haven't done these yet - start there.
willikc
thanks guys I've already sprayed a whole can of carb cleaner on it im going to get a new fuel filter and ignition parts friday and try that thanks
