1975 70hp evinrude thermostat replacement
jaeys
Just wondering if anyone knew if it is easy to change out the thermostat in this motor. Is it easy to get to or do I have to tear the whole motor apart to get to it?<br /><br />Thanks
OBJ
Re: 1975 70hp evinrude thermostat replacement
Easy to do Jaeys.....look at the top of the head and you'll see a more or less triangular cover. The t-stat is behind it. There is several bolts holding it on.....four or five I think....if yer sure the t-stat needs changed out, go to local dealer and get the parts first so you'll have them at hand. Shouldn't take no more than an hour to do the job.
