Hi!<br /><br />My Johnson 60 -89 VRO gives out a constant alarm when turning key switch to on position. <br /><br />It started when the main power switch was turned off with the engine running. It was the third time someone kicked the switch in accident. Earlier the beep stopped when the switch was turned on again. But not this time.<br /><br />I believe that the alarma horn is defective and needs to be replaced.<br /><br />I have still not searched for the problem and I would appreciate some good advise. Can I easily open the control box and check the horn?<br /><br />I added this as a new topic because of the nature of the cause to failure.<br /><br />Robert
