I installed a new Teleflex Vector tach on my 1974 Johnson 85hp. At idle it registers 950 revs and at cruise speed 4000 which I believe is accurate, but after 4400 the tach begins to fall eventhough the engine rpm's go up.<br />I tested the voltage at the battery and get 13.5 vdc at idle so the rectifier seems ok.<br /><br />What should I look look for next??<br />Thanks<br />Tim
