I bought a 95 Gruman w/ a 50 hp Johnson this past weekend.The alarm sounds every couple seconds and faster if the RPMs go up.I believe this is an oil issue.I believe this boat has sat for a couple of years because the gas was bad and I relpaced it and<br />now it runs good.I drained the oil tank[it was clean<br />inside also the screen looked clean]and replaced with new oil.How can I test the oil pump to see if it works[it is getting 9 volts]What should I test or look for? Also I do not believe this has been run much because I think it still had the original plugs in it?Also it seems to be getting alot of water which is why I think it is oil related! Thanks for any help,Dave
