Help! Evinrude 15hp 1975, Engine refuses to fire-up! New Plugs, Checked for spark & ok, reset points & timing cleaned up stripped carb & ok, don't seem to be any fuel getting through!! checked fuel filter ok, and fuelled up! We can only think that our compression is too low! 50lbs + 55lbs would this cause pump not to work? Would appreciate any advice. Model 15554C (1975 I believe)
