Help with year of Motor
Bill kubiak
I have an 8 hp Evinrude and the model number is partially missing all I can make out is F 8R??TB<br />It is either a 95, 96, or 97<br />Is the model number anywhere else on the engine besides the mounting bracket??
OBJ
Re: Help with year of Motor
Bill....the "T" would indicate a '3' in the year. Look on top of the block for a large freeze plug. The model number should be on there.
Bill kubiak
OK I found the freeze Plug and it looks like it is F8RETB will that make it a 1993??<br /><br />Can you tell from that number the shaft length?
rickdb1boat
1993 it is, Can't tell from the model number if it's long or short shaft. But you can from this:<br /><br /><br />
Bill kubiak
I measures and it is 17 1/2 inch almost a long shaft
rickdb1boat
Almost, Bill, but not quite. It would be considered a short shaft. Do you have it mounted on a boat now or what type of boat are you going to use it on?
Bill kubiak
I want to use it on my sailboat. I have a 1983 long shaft Johnson on there now but it is unreliable. I wondered if I could swap out the shafts, what do you think????
rickdb1boat
I'd give it try. You would of course have to make sure the water tube matches up, along with the shift shaft and splines on the driveshaft. Others' may know for sure if this is possible. Gear ratio may also be different, too. But that may not be such a big deal on a Sailboat, as you could re-prop it to compensate for that. All you can do is give it a try. On that small of a motor, it should be no big deal to drop the lower unit's and check them out...<br /><br />EDIT: Or you could trade it for a long or Extra long shaft...
