86 Johnson 150 t/t prob.
Rob. PB
The tilt and trim just decided to work sometimes. If I play with the switch on the throttle sometimes it works sometimes not. The up and down switch's at the front of the boat same thing. There is not one at the motor so I can not check it. Sounds like a wireing prob. to me or a switch prob. but I am at a loss at where to look or what or how to run a check. :confused: :confused:
twista_02
Re: 86 Johnson 150 t/t prob.
The easiest way I can think of trying to figure out what it is would be too pull both switches out, or the wires for them(there should be three on each switch) and touch or jump the outside wires one at a time to the center one. If the trim works fine when you do that, I would think it was the switch.
