I own a Johnson 70hp 1996 model. All electrics are fine except for the temperature alarm which does not work. I dismantled the blocking diode from the engine block and it grounds when placed in boiling water so it should be ok. The Quickstart function does not work too ... thats why I suspect the CDI with respect to temperature is not functioning. Anything else I should check to make sure ?? Otherwise all is fine.
