I have a '89 Evinrude 200 hp V6. While running the boat my alarm came on with a constant beep and I immediate noticed a considerable power loss. After about 5 minutes I could start the boat without any alarm and it would perform fine. This happened twice as I was returning to the boat launch. I had normal water pressure and a good stream coming from the engine. What could cause the alarm to sound with a significant loss of power and then after a short rest be fine?<br />(Also, although it may be unrelated, I also noticed that the engine was running/producing between 11.5 and 12.5 volts instead of the usual 13+.)
